1994 Delica Space Gear ~ SOLD
MitsuBanshee
- Vehicle: Delica Space Gear
1994 DELICA SPACE GEAR EXCEED PD8W LOWROOF w/ DUAL SUNROOFS $15700
This very clean Delica is in excellent condition - fully updated and inspected, runs like a top.
White with a Tan interior
2.8 Intercooled Turbo Diesel
Auto with OD, 2WD, 4WD, AWD
118800Km
8 seats, all with seat belts, very versatile middle seat (swivels front, side, back, flat)
both fog and driving lights
Driving mode switch: sport, hold, economy
Very clean undercarriage, body and interior, no rust or corrosion. Obviously treated well by previous owner in Japan. I am the first owner of this vehicle in Canada.
Here is a list of the extensive service work that has been done over the past 4 months since I've owned it. All parts are new factory OEM:
brakes
machined discs
flush brake system - ATE process
repacked all hubs
all belts
all fluids: engine, front diff, rear diff, transfer case, transmission
all filters: oil, air, fuel, ultrasonically cleaned OEM transmission filter
"Delitune" includes timing, ultrasonically cleaned injector nozzles
glow plugs
valve cover gasket kit
fuel injection pump seal
coolant expansion tank
radiator
all hoses: upper/lower
water pump
thermostat
heavy duty coolant
block heater added
CV boot
front upper ball joints
steering rack boot
inner/outer tie rod ends
rear sway bar end links
rear sway bar bushing kit
all grease points
all compliance includes "E" coded headlights, daytime running lights.
Other upgrades:
Odyssey PC1500 battery
Procomp ES 9000 shocks
6 Hankook Dynapro AT/M tires - 245/R75/16, 31x9.5, about 1000km of use
6 16x7 Procomp Rock Crawler wheels
Full 2" Lift Kit, machined aluminum spacers:
2" rear lift via coil spring spacers
Rear swaybar dropdown brackets
Rear brake compensator dropdown brackets
2" front lift via 1" upper balljoint spacer w/ torsion bar adjustment
Fitted Mats in front and rear
New Limo Tint on all rear windows - will not fade
Pro detailed inside and out: completely shampooed headliner, curtains, seats and floor, polished and waxed
Wheel Alignment
Hydraulic Jack
Still have the 5 stock aluminum rims and tires
Also still have the old shocks in case you would like to remove the lift and larger tires to run the stock 28"
Removed, but still have, the stereo, pop-out TV screen and navigation system
With all the major bills totaled up, I'm now up over $17000. It would be nice to sell close to this however, I am open to offers. Also, there is a custom made aluminum safari rack and cross bars that could be negotiated as well - paid $2350. 93"x48" full roof length, front lockable wind wedge compartment, middle hatch over sunroof, safari rack removes to leave heavy-duty cross bars on roof.
I was intending to rig this vehicle up for overland touring and really wanted any possible issue taken care of beforehand... not in the middle of nowhere. This was definitely done! Now this Space Gear is in tip-top shape, ready for any adventure. This is a very special Delica that has been meticulously inspected and updated. Please let me know if you have any questions, want more information or some more pics. My phone number is 250 770 7842 or reply to this post.
Thanks everyone
118800Km
brakes
machined discs
repacked all hubs
all belts
glow plugs
radiator
water pump
thermostat
heavy duty coolant
block heater added
CV boot
steering rack boot
all grease points
Other upgrades:
Wheel Alignment
Hydraulic Jack
Thanks everyone
MitsuBanshee
Re: 1994 Delica Space Gear
Here are some more pictures - sorry about the large size.
Please resize your images.
They are huge !
They are huge !
MitsuBanshee
Let's try this again - sorry everyone!
- rsz_p1000280(1).jpg (67.43 KiB) Viewed 9636 times
- rsz_p1000276(1).jpg (109.93 KiB) Viewed 9637 times
- rsz_p1000325(1).jpg (148.37 KiB) Viewed 9637 times
- rsz_p1000318(1).jpg (150.51 KiB) Viewed 9633 times
- rsz_1p1000272(1).jpg (132.58 KiB) Viewed 9631 times
- rsz_p1000298(1).jpg (132.11 KiB) Viewed 9634 times
- rsz_p1000444(1).jpg (141.36 KiB) Viewed 9623 times
MitsuBanshee
...and a few more.
- rsz_p1000457(1).jpg (175.47 KiB) Viewed 9610 times
- rsz_p1000452(1).jpg (151.02 KiB) Viewed 9608 times
- rsz_p1000451(1).jpg (159.44 KiB) Viewed 9599 times
- rsz_p1000283(1).jpg (115.66 KiB) Viewed 9600 times
- rsz_p1000294(1).jpg (112.26 KiB) Viewed 9595 times
- rsz_p1000295(1).jpg (132.69 KiB) Viewed 9589 times
- rsz_1p1000291(1).jpg (121.8 KiB) Viewed 9582 times
psilosin
- Vehicle: L400
I have seen this Delica in person and it is very clean and very sexy. A bit out of my price range at the moment or it would have already been added to the herd. Seller seemed like a nice guy as well. Someone is going to be a happy buyer. Good luck with the sale!
MitsuBanshee
Re: 1994 Delica Space Gear - SOLD!
This Delica is now Sold... I wish the new owner many awesome adventures!
Thanks everyone
Thanks everyone
- Jungle Jon
- Vehicle: Toyota Tacoma
Re: 1994 Delica Space Gear ~ SOLD
Thanks MitsuBanshee! Let the awesome adventures begin!
madmazda
- Vehicle: 1994 l400
Jon did you get this l400 ???? I'm guessing you sold the l300 ???? cant wait to see this deli....
- White Mule
- Vehicle: 1991 Delica L300
This means you can not park next to me, as I own the rights to everything WHITE!madmazda wrote:Jon did you get this l400 ???? I'm guessing you sold the l300 ???? cant wait to see this deli....
Sweet ride. Peters anyone?
Thanks,
White Mule
White Mule
- Vehicle: -
Only in AlbertaWhite Mule wrote:This means you can not park next to me, as I own the rights to everything WHITE!madmazda wrote:Jon did you get this l400 ???? I'm guessing you sold the l300 ???? cant wait to see this deli....![]()
BC is miiiiiiiiinnnnneee
- Jungle Jon
Yes, she's mine now.madmazda wrote:Jon did you get this l400 ???? I'm guessing you sold the l300 ???? cant wait to see this deli....
