Need advice for L400 wheels - Vancouver
tonydca
Post by tonydca »
Has anyone got any non-Delica (i.e. not-brought-in-from-Japan) wheels on their L400? I'm looking locally for a second set for some snow tires, and I keep hitting the same story.
I understand that the stock Delica Wheels are 6 inches wide, with 6x5.5inch (6x139mm) bolt patterns and a 108mm centre hole - no idea about offset - but whenever I find a potential set on Craigslist, most sellers come up blank when I ask particularly about that centre hole.
Most just say "I dunno - they came off a <<insert vehicle here>>".
I understand from earlier posts that L300 wheels and some (all?) Toyota 4Runner wheels are 105 mm centres.
Has anyone bought local wheels that fit their L400? Like, say off a 96 Chev Blazer, or a 2001 Toyota Tacoma, or ??? I had a dig around on the internet, but a detailed list of cross-manufacturer factory wheel dimensions doesn't seem to exist.
I'd like to maximize my chances of success before I drive out somewhere and try to swap one in to see if it fits. Thanks,
Tony.
Re: Need advice for L400 wheels - Vancouver
Tony, I'm pretty sure that there is a post in here somewhere about this and I think it was by Jessie.
6x5.5 bolt pattern - Toyota/Mazda/Nissan/Mitsubishi (jfarsang-second post down)
So it appears to me that you would get these rims off a Toyota, a Mazda, a Nissan or a Mitsubishi. Have I misunderstood your question?
Hi Tony
6x5.5 bolt pattern
Usually 15/16x7" wheels is common
Center bore hub must be 108mm or more
jfarsang wrote:6x5.5 bolt pattern - Toyota/Mazda/Nissan/Mitsubishi
jfarsang wrote:http://www.delica.ca/forum/machining-ri ... -7388.html
jfarsang wrote:Mitsubishi L300 Delica center bore hub = 106mm
Mitsubishi Montero/Pajero Gen I = 106mm
Mitsubishi L400 Spacegear center bore hub = 108mm
Mitsubishi Montero/Pajero Gen II = 108mm
tonydca
Post by tonydca »
Thanks Jesse, I saw info that from your previous postings already.
But apart from the L400s, Monteros and GenII Pajeros you list, I can't find info showing any other vehicles out there with the 6x5.5 bolt patterns and 108+mm centre bore as "standard factory" wheels.
If I call a guy who is selling, say, a set of 6x5.5 rims off his Chevy Blazer, and I say "how wide is the centre hole?" Derp derp derp "I dunno - looks like about 4 inches or so". Driving all the way out to Chilliwack to find that they don't fit would be a pain in the a$$.
And I'd rather not go through the process of machining out the centre hole if I can possibly avoid it. So that's why I was wondering if anyone has swapped out rims from a non-Mitsubishi North American vehicle and had them fit unmodified onto their L400. Just exploring my options.
Thanks everyone for their input; cheers,
Tony.
Unfortunately, that's really the only way. See them in person unless they know what the offset/bore measurements are.
Most aftermarket chevy/toyo/mitsu/nissan wheels are 108+mm center bore
tonydca
Re: Need advice for L400 wheels - useful chart found!!
Post by tonydca »
tonydca wrote: Has anyone bought local wheels that fit their L400? Like, say off a 96 Chev Blazer, or a 2001 Toyota Tacoma, or ??? I had a dig around on the internet, but a detailed list of cross-manufacturer factory wheel dimensions doesn't seem to exist.
Tony.
Hooray for the internet! Useful cross-reference chart of factory wheel dimensions:
http://adaptitusa.com/referencebook.htm
So from this, it looks like the likely donor culprits are (assuming 1/2-inch or 12 mm bolt diameters):
Acura SLX
Chevy Canyon/Celsor
Dodge Ram 50 '79-93
Dodge Raider (no surprise there!!) :-D
Ford Courier Pickup 77-84
Honda Passport 94-03
Infinity QX4 (but *not* Nissan Pathfinder, apparently...)
most Isuzu trucks/SUVs
Lexus LX450 or GX470
Mazda B-2xxx series pickup 77-93
Toyota FJ cruiser and 01-07 Sequoia
Tony.
I can't see any on the list that have the same/similar offset as our Delica's except maybe the Nissan's. Would be good to find out :M
tonydca
Post by tonydca »
jfarsang wrote:I can't see any on the list that have the same/similar offset as our Delica's except maybe the Nissan's. Would be good to find out :M
How do you know what the offset is/should be? I can't find it on that site...
Tony.
ShaneA
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=12984
Vehicle: '94 Space Gear LWB
Post by ShaneA »
I believe the offset is 4 1/4", I'm sure Jesse will correct me if I'm wrong.
I managed to find a set off a Toyota 4runner. Before I met the guy I asked him if he would mind waiting while I mounted one of the wheels on to the front of my van. I measured the offset, mounted one tire, then drove a few circles around the parking lot to ensure there was no rubbing. All good.
Shane
Mr. Pistachio
Vehicle: L400 LWB Super Exceed
Post by Mr. Pistachio »
Hey Tony,
On the site you've posted I've found that Suburban 71-91 wheels are also compatible. As I recall, those trucks are everywhere and I can imagine the ridiculous amount of wheel available at the scrapyard for those!!! It might be a lead to something! Especially if you're looking for steallies for the winter!
Antoine
Return to “L400 Technical”
