TX-1 lightweight offroad rims - Group buy?
Vehicle: -
Post by fexlboi »
I'm going to order rims from Australia and want to see if anybody else out there is interested in getting a set too. These rims are bullet proof and have a similar strength than steel rims but still are relatively light weight. Load rating is 3000lbs per rim. These are the replacement of the legendary Outback TX-1 rims, which got used a lot for offroad racing, but not available anymore. They are in my opinion the best affordable offroad rims for Delicas. Steel rims are too heavy and take too much power away but regular street alloy rims a prone to crack if they get abused offroad.
http://www.performancewheels.com.au/industrial.asp
They are available in silver, black and in white.
So far I asked for these common sizes, but there are more available.
15x7
6 on 139.7
-4mm offset
8.6kg
67mm to 108mm hub bore
AU$90
16x6
6 on 139.7
-6mm offset
8.8 kg
67 to 108mm hub bore
AU$120
16x7
6 on 139.7
-4mm and +4mm offset
9.07kg
AU$120
The rims itself are actually not expensive, but obviously the shipping is not cheap. It depends how many people are interested. If we order two sets, the shipping would be around AU$240 per set, but if we order three or more we can bring it down to below AU$200 per set.
So what do you guys think? Anybody interested?
Re: Durable offroad rims - Group buy?
$120AU x 5 rims + $200 AU for shipping comes out to $756 canadian.
$152 per rim shipped. Not bad. 8-)
ShaneA
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=12984
Vehicle: '94 Space Gear LWB
Post by ShaneA »
Those rims look great. I'd love to have another set of rims for my off road tires. Unfortunately no cash at the moment for any non-necessities for the van. :-(
Vehicle: -
Re: TX-1 lightweight offroad rims - Group buy?
Post by fexlboi »
Really?! Nobody is interested?
I am but they don't have the offset I'm looking for :-(
freeheelsteve
Vehicle: 84 Westfalia/94 Exceed Crystal Lite
Post by freeheelsteve »
Which ones would work best for 31s?
Looks like there are different colors as well, no?
Steve
freeheelsteve
Oops, you said right in there, the colors. sorry.
Steve
Vehicle: -
Post by fexlboi »
freeheelsteve wrote:Which ones would work best for 31s?
15x7 would work
Vehicle: -
Post by fexlboi »
Last call! If anybody else is interested, let me know.
I'm going to order them this week.
Paule
Vehicle: 1997 L300 Active World
Post by Paule »
delicat wrote:I am but they don't have the offset I'm looking for :-(
Not to hijack this thread...
But what does the offset refer to? And how is it measured?
p
Vehicle: -
Post by fexlboi »
p
http://www.tirerack.com/wheels/tech/tec ... techid=101
Paule
Post by Paule »
Thanks.
Is there a maximum L300/400s can do before it causes problems?
p
Vehicle: -
Post by fexlboi »
Paule wrote:Thanks.
p
Just can speak for l300s. On a 7" wide rim you don't want to go with more negative offset than around 5mm. Otherwise the front wheels sticks out too much. Depending on your tire size, you might need to use the grinder in the front and trim a little bit.
Most of the time you are limited with the available offset from the rim manufacturer anyway.
