SWB roof racks
pajerry
Re: SWB roof racks
Post by pajerry »
Jaz wrote:Gents, it could be worth having a browse through the Aussie forums, as we have many more shorty Paj's down there and I'm sure there's a few tried and tested options they've used.
Just a thought :M
Google brought up a few threads, but surprizingly few. It depends how you word it I guess..
Raule Duke
Vehicle: 92 Pajero SWB
Re: SWB roof racks
Post by Raule Duke »
I went to the wrecker and found a truck with roof rails that were approx the correct length and width and came up with this
"There's a uh, big machine in the sky, some kind of, I dunno, electric snake, coming straight at us!"
pajerry
Re: SWB roof racks
Post by pajerry »
This was my last choice, but now that I see it all together, it seems like the best way to go. Better quality than the yakima crap, bigger feet etc.
Do you remember what vehicle it came from? What did you need to remove it? Saws-All? lol
Jaz
Vehicle: "Rusty" no longer :(
Re: SWB roof racks
Post by Jaz »
I was going to say as well, when we attached the roof rack to my 4runner, which is of a similar sort to Raule's above, I went over to a buddies place and we used something similar to a pop-riveter that is actually meant for this purpose. He bought it home from his work (Toyota Mechanic). Can't remember the name of it, but we drilled the holes first, then this thing had a really nice method of sealing it right off and spreading the force a little, plus with the aid of a touch of silicone on the inside.
Could be worth pinging a mechanic mate if you have one, or asking around at an auto-shop. Much better than self tappers ;)
(Edit: Actually, I think that was originally going to be a reply in Mr Flibble's current thread, but here works too.)
loki
Re: SWB roof racks
Post by loki »
the one link in the uk forum shows how to fit the factory ones that you could get from a wreckers or an importer maybe?
http://www.pocuk.com/forums/viewtopic.p ... highlight=
Pajerist
Vehicle: 1993 Pajero 2.8L 5-speed LWB
Re: SWB roof racks
Post by Pajerist »
I'd rather die than allow to drill my truck's roof :)
If you need more cargo capacity why do not upgrade to LWB?
Fight for Right to drive from Right!
http://forum.import-era.com/index.php
http://www.ivoac.ca
Raule Duke
Re: SWB roof racks
you'lll find that when searching at the wrecker's, most of the roof racks seem to be manufactured by the same factory. they all seem to be almost identical (mot of them not all) I got this one off a Nissan Frontier... however i'm pretty sure that the newer style (around 98 or 2000 year) blazers and other smaller SUV's have them
I took the head liner out and used things called "nutserts" to mount them (they are a rubber "Crush nut" thing) availablt at lordco for cheap and then used marine grade epoxy on each bolt to ensure strength and seal
Jaz
Re: SWB roof racks
Post by Jaz »
Raule Duke wrote:I took the head liner out and used things called "nutserts" to mount them (they are a rubber "Crush nut" thing) availablt at lordco for cheap and then used marine grade epoxy on each bolt to ensure strength and seal
Ah ha! That's what we used. Although we didn't take the roof liner out, just inserted from the top.
pajerry
Re: SWB roof racks
Post by pajerry »
I just realized that I took home the same rack from the wreckers. You're right, there are lots. I figured it was also a good thing in case you need parts.
Return to “Pajero”
