Spent the morning @ Custom Trailer Mfg. in Coombs watching Chris size/mount deltron's new roof basket.
Chris has been welding aluminum for 10 years and makes all Custom's baskets, super friendly guy.
he worked from drawings I gave, except that he modified the wind faring by boxing it in.
and used a prefab piece of aluminum for the corners which adds strength and looks slick.
I'll be adding a home made awning and strapping down a 6'x8" abs pipe as well.
heres another story with the pics to go with it:
deltrons rear hatch doesnt stay up anymore,
here is a solution in lieu of expensive new struts
Chris welded it up out of scrap and threw it in.
Leaving for the summer in 10 days... back out to the shop I go.
colby
Deltron gets a new tophat
cobsweb
- Vehicle: 92 Exceed
- IMG_1137.jpg (292.65 KiB) Viewed 4692 times
- IMG_1135.jpg (185 KiB) Viewed 4690 times
- IMG_1144.jpg (294.75 KiB) Viewed 4692 times
- IMG_1147.jpg (201.87 KiB) Viewed 4689 times
- IMG_1149.jpg (180.62 KiB) Viewed 4688 times
- IMG_1151.jpg (202.87 KiB) Viewed 4687 times
- IMG_1153.jpg (162.86 KiB) Viewed 4682 times
Re: Deltron gets a new tophat
Very nice! And a cool and simple solution for droopy door struts.
- Vehicle: -
Wow, that's a nice roof rack! The seams a very clean as well. Looks like a very good place to go for custom fabrication on the island.
Neat detail with the little wind deflector.
What's the price tag?
- Luna-Sea
Very Nice!
Is that the place on the road into Coombs on the right,
before the turn off to Coombs Country Auto?
Right On!
Right On!
cobsweb
that's the place, a bunch of aluminum trailers out frontLuna-Sea wrote:Very Nice!
Right On!
had a highroof l300 exceed rotting away in the back!
also saw a 3 different JDM bush bars in a pile. one was a nice aiba works stainless probably for a pajero.
kept it to the triple digits but not by much.fexlboi wrote: What's the price tag?
- Vehicle: -
That's what I expected, but for this quality work it's totally worth it.cobsweb wrote:kept it to the triple digits but not by much.fexlboi wrote: What's the price tag?
Colby, nice hat. In my down the road to-do list is a full scale aluminium rack/deck. I was thinking of using eight towers for weight distribution ~ the idea being having the option of putting table and chairs on the deck and watch the show, &c.. What sort of weight can you get into your basket with six towers? Would you feel comfortable using your basket as an observation deck? It looks pretty skookum!
Cheers!
Cheers!
cobsweb
I wanted to be able to use the rack as a deck for tenting/couching/viewing.
so it was designed with that in mind. the rack itself should hold atleast 600lbs.
its super solid to walk on. I was jumping on it yesterday.
I'm sure 8 towers with this type of rack could easily support more weight than you'd want to drive with.
also the spare tire mount is removable, ie. leaves a completely flat deck.
and inside dimensions are 4'x 8' to make carrying lumber easier.
FalcoColumbarius wrote:Colby, nice hat. In my down the road to-do list is a full scale aluminium rack/deck. I was thinking of using eight towers for weight distribution ~ the idea being having the option of putting table and chairs on the deck and watch the show, &c.. What sort of weight can you get into your basket with six towers? Would you feel comfortable using your basket as an observation deck? It looks pretty skookum!
Cheers!
- L300Foca
- Vehicle: Mitshubishi L300 2.5 TD GLX
