Probably going to use a converted HDT (Heavy Duty Truck) re-licensed as a motor home in Ontario pulling a 36' fifth wheel RV. If you want more information, this is forum has the most active members with HDTs... http://www.rvnetwork.com/index.php?showforum=32
Here is a good example of a member who has lengthened his truck to accommodate a jeep. Not nearly as cool as a Deli tho
, I want to bring our Deli (300) with us, but that raises a few issues. If we put it on the deck of the truck, we end up with a very long truck (probably close to 300" wheelbase), which is expensive to source and hard to park in a campground. Or we pull the Deli behind the 5th wheel RV, either all four wheels on the ground with a towbar http://www.blueox.us/Towbars/towbars.htm, or with either the front or back wheel on a towing dolly http://www.towbartowdolly.com/. If we use a dolly, we can lift it up on the back of the truck when not in use. I'm worried about transfer case / transmission damage from towing 4-down with a towbar.
I'm open to all ideas. At this point a dolly with the Deli's front wheels on the ground seems like the better answer because of the free-wheeling hubs, but I would love to hear some debate.
George
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
