 Anyway, I changed the oil this weekend, and these are some of the observations I made (for the driveway mechanic) while doing that, and while installing the rear hitch and the trailer wiring harness:
 Anyway, I changed the oil this weekend, and these are some of the observations I made (for the driveway mechanic) while doing that, and while installing the rear hitch and the trailer wiring harness:- -the 31" tires are great because I can shimmy under the vehicle for short periods without putting the vehicle up on the ramps;
 -the underside of the Pajero is much beefier than the Delica (should be more solid when I do get off the road);
 -the mounts for the trailer bar are more accessible;
 -the oil filter is located in a much better place, and it's oriented vertically (instead of horizontally);
 -the oil pan plug is clear of the frame, so when the oil comes out it doesn't splatter all over the frame (and then into the catch pan);
 -the oil cooler holds a lot of extra oil which comes out all over hell's half acre when the oil filter is backed off (much messier);
 -and, the extra height and having to reach over the engine bay necessitates a stool or step ladder to reach the oil filler cap if ramps are used (might try it flat on the ground next time).
Overall, I'm happy with the SWB Pajero, and if we still had both of my step-daughters living with me, well, we might have gone for the LWB 4-door. I still miss the Delica, but I'm loving this new Pajero. Heck, even my dad is interested for when he has to return his leased truck next month.
 Maybe next time I won't be such a slop.
 Understand? Of course it makes perfect sense when I describe it that way - right?
