FalcoColumbarius ~ taken out of context (see: First time off roading...) wrote:If you are using GPS: Be careful. GPS is based on the map datum: WGS84. Which means "World Geodetic System ~ 1984". What this means to your GPS is the co-ordinates of the land are based on the year 1984. So if you programme in a direct route from point A to point B it may pick a road that was deactivated in 1985. That road could be very dangerous. Remember, Common Sense.
Don't go with falco you will be lost in no time!
wgs84 has nothing to do with when roads were built used and deactivated.
it is the elliptical shape chosen to be the most accurate representation of the earths raw surface elevation.
the earth is not a perfect sphere so this is the egg model they use.
cheers
