Two wires on the TPS
one reads constant 4.5-5v
one reads between 0.2 - 2v * this is the one to use as a gauge
Overdrive
rudy27
- Vehicle: delica space gear
Re: Overdrive
Right its all good now,I must have misunderstand the instruction, was checking voltage on blue wire with red stripe (blue and red wire) but it was the other one,luckily I am not a bomb tech.But my TPS run out of adjustment space I had to drill new holes for the set screws(mounting screws) in to the plate its mounted on.
Thanks to all of U who kept responding to my crying,now it runs like it should.
Back to the garage time to build a trailer hitch.
Cheers Rudy.
Cheers Rudy.
