athabasca wrote:Can someone point me to DIY info on compliance for a pajero? I don't even know what side markers are, but I'd be quite willing to pay myself $400/day to giter'done. Is it just headlights and tires, period?
Side markers are on every vehicle. They are the red(rear) and orange(front) reflective markers you see at or close to the head/tail lights.
I did a post recently with a list of what a normal inspector looks for.
4x4wire.com has a Pajero-specific forum under trail talk forums along with the necessary compliance work needed.
Pajero just like any imported vehicle has to go through the same inspection.
These things have to be in proper working condition to pass :
tires have to be in good shape (99% tires coming from Japan have severe weather cracking and are not safe to drive on, ie. Rubber peeling while driving, blown sidewalls.)
tires have to had the load rating,psi and/or Dot approved stamp.
suspension components
balljoints/tie rods/swaybar links bushings/cv boots/shocks
brakes
calipers/pads/rotors/hubs
lights
dot or e-code LHD headlights/marker lights/day time running lights/3rd brake light
no massive leaks/window cracks
seatbelts have to be working
there is a longer list somewhere back
basically an inspector can fail you on any of those things
some inspectors are anal and very meticulous while others don't care or are lazy
there have been some good inspection facility shutdowns and licenses revoked because of poor inspections (passing vehicles with apparent problems and/or not up to spec)
if you fail, you can get it redone as many times as you like. It just costs money
4x4wire has been around for a long time and every bit of Pajero information you can think of has been discussed there. Good source of information.
