94 Delica L400 SPACEGEAR T-Diesel 79k Auto * SOLD*
MardyDelica
Post by MardyDelica »
1994 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Automatic with super select transmission AWD & 4x4, Super exceed model, Blue with grey color, L400, has 97,000 kms on it.front sunroof & all rear shades work, nice clean Van
with crystal lite roof, A/C, 7 passenger captain chair which you can swivel it to 360degree facing the front or back, 134A AC which is the same freon that we used here in canda its upgrade now, fully loaded, will do full B.C.Provincial compliance, will install New original Mitsubishi headlight E-Code, and full service for this newly designed L400 Delica.
its rare to find a super exceed now in japan which such a low mileage.this is a 4wheel disc brake vehicle, it stop like a newer model mini van. which is a big advantage fro this vehicle. has included books & record of this vehicle as you can see in the pictures;
it has a front & rear crome bumper which looks neat to this L400.
include the ff: thing to be done for this L400:
1.) 1 year or 12,000 kms warrantty on it:
2.) 4 new yokohama all terraine tire
3.) new radiator
4.) new water pump & thermosthat
5.) install new Led day time running light to prevent burning the headlight combination switch.
6.) will change new front & rear brake pads if its 50% pads remaining.
7.) inspect all the brake hose & suspension if need to repalce will change it.
8.) do clean injector & pre set the injection pump so proper timing
9.) do change the transmission filter & fluids
10.) change all the gear oil
11.) new fan belt
12.) do front wheel re-pack for this L400 which is a must to any L400 that came from japan
13.) do machine rotor when putting new front & rear pads to make the stopping brake more smoother.
14.) will do full B.C.compliance for this vehicle, you dont have anything to do just insured it when buying this van, we will do the rest to make it easy for you
15.) will inspect everything from undercarriage, frame chassis & body of this car
16.)do front alighnment
17.)new fuel , oil & air filter
18.) test drive this vehicle in the highway to ensure this vehicle runs straight with out any bybration when it reach 100-120kms per hour
19.) install 4 new shocks pro comp 9000 series with polyuretane bushing on it
20.) inspect water bottle for anti freeze if any sign of crack if any crack well replace it.
21.) insepct all the glow plug if working properly
22.) do put 70/30 water of anti freeze to ensure the maximum engine protection of this vehicle whether its a cold Or summer weather.
23.) has PIAA fog light on it.
24.) has orig mitsubishi front skid plate attached on it.
Vehicle is in Transit will arrived next month Feb.
This is 1995 model as it build dec 1994 so everyhting is suppose to be the same as 1995 build model from engine component & other related updates of L400 parts & suspension.
Stock # PE8W
Any questions please call me:
604-247-2111/ 604-720-6144
thanks,
L400a 79k.jpg (63.36 KiB) Viewed 2925 times
L400b 79k1.jpg (56.82 KiB) Viewed 2924 times
L400c 79k2.jpg (51.51 KiB) Viewed 2924 times
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 79k Auto in transit
Hi, This L400 is on HOLD Now
Recieved Deposit:
Thank you
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 79k Auto * SOLD*
This L400 is SOLD now
Thank you
