While doing an oil change today, I pulled off all the armour from the beast and found something interesting. There are a few of you out there who have changed their front sway bar end bushings due to bad stages of rot or just plain missing. Mine are in okay shape but are slated for replacement on my to do list, while snooping about, I found my sway bar main mount bushings in horrible shape. I have only a slight clunking remaining in my front end and though this may not have anything to do with it, I thought it is something worth mentioning, as I will be ordering 4 sets of new bushings to do my whole sway bar.
Here are the pics.
Soft underbelly of the beast.
Drivers side.
Drivers side close up.
Passenger side.
Passenger side close up.
My outer drivers side bushings.
I reccomend that you all check yours next time you are crawling around, if you haven't already.
