Excuse my ignorance, but which delica has the 4m40, and which heater would that be? I talked to sahir at maximum overdrive, and he was happy to give me a part number that lordco had in stock. First I'd like to confirm that it is in fact a 35mm plug and that I install it on the right side (from drivers perspective) and that it's the plug at the rear of the engine. Also, since I have never installed a block heater, are there any tips specific to this motor that would make my life, and the pajeros life easier.
Thanks in advance!
block heater sucessfully installed l400
pajerry
Re: block heater sucessfully installed l400
Manitoba deli
I'm pretty sure the block heater I installed on my 4M40 in the l400 was a 40mm frost plug.
Jason
Jason
- DelicaFreaka
- Vehicle: 94 L400 4M40
You are correct Jason it is 40mm.Manitoba deli wrote:I'm pretty sure the block heater I installed on my 4M40 in the l400 was a 40mm frost plug.
Jason
Zero Start Brand
Part #3100049
Available at Lordco
********** Starship Delica **********
"To boldly go where no man has gone before"
- Erebus
- Vehicle: 1992 Super Exceed
Ummm, the 4M40 in the zerostart catalogue is listed for the Mitsu Fuso, not the Delica.
You'd better make absolutely positively sure of which frost plug and what part number heater, because once that frost plug is out, you are committed.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".- DelicaFreaka
A piccy is worth a thousand doubters......................Kirk out.Erebus wrote:Ummm, the 4M40 in the zerostart catalogue is listed for the Mitsu Fuso, not the Delica.
4M40 is in fact the L400 engine.Erebus wrote:Ummm, the 4M40 in the zerostart catalogue is listed for the Mitsu Fuso, not the Delica.
