When you look underneath at the rear sway bar mounts, two 17MM bolts thread up into the u-channel underneath the Delica body.
To date, I've counted 9 Delica's in various trim/exceed, etc... configurations with no factory rear sway bar.
There are no threaded holes. Just flat steel. There are no L-brackets that the sway bar would bolt onto the axle (u-bolt plate).
I've always removed my rear sway bar as it has zero effect on the handling, limits rear articulation and usually comes with shot bushings.
I'm wondering aside from the 9 I've counted, who else has their Delica that came from the factory without a rear sway bar ?
 "I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
 Call me BCDelica-less
