Inclinometer Repair
Fionna
Vehicle: 68 VW bus
Re: Inclinometer Repair
Post by Fionna »
Hi! We have just removed the 3 pod instrument bank off the dashboard. There do not seem to be any screws on the front, just the back. We see 8 screws, 2 of which seem to be holding the electrical connector on, to get to the instruments, are all of the other six screws to be removed? And then does the back simply come away from the rubber front? Is there any adhesive or sealant between the back and the front?
We have reviewed the photos in previous posts, but I'm still unclear exactly how to remove the individual instruments.
We see that a suggestion was made to use mineral oil or gyclerin, and we wonder if anyone has determined which would be the correct replacement fluid?
I wonder if anyone has taken the inclinometer in for repair and if so to whom have they taken it in the Vancouver area. If the bowl is cracked (we are leaking oil so this might be a possibility) is a replacement available? Or does anyone have one they would be interested in selling?
Thanks!
Fionna
Hi Fionna,
I can't help with the details of taking a pod apart, but if you contact ccautos (250 954-2157) www.coombscountryautos.com, I'm certain Glen has a full working replacement pod or three for sale... :-D
asmecher
Vehicle: 1993 Delica
Post by asmecher »
I recently had to fix an inclinometer with the same problem (stuck on an angle)... A past owner had nearly done the same thing described above (tried to tear the face off without undoing the screws), leaving some broken plastic. It appears as though my inclinometer never had any fluid in it (??) -- unless someone removed the seal from the back and drained it.
In any case, the problem was that a short metal pin that comprises one of two pivots had fallen out of place. I was able to tweeze it back into place and fix the broken plastic, and now the inclinometer works again, fluid-free and all (though it's probably a little bouncier than one properly filled with oil).
Cheers --
Alec
Modsqwad
Vehicle: 91 Deli & KLR 650
Post by Modsqwad »
I gutted mine and installed the GPS in it. Wiring came up through from down below. It turned out ok. When the van comes back from paint shop I'll post a photo.
Andy
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
it would be cool to just replace it with a illuminated compass like this:
http://www.autosportcatalog.com/index.cfm?fa=p&pid=5570
but i would really like to see pics of a GPS mod. :-)
al
Modsqwad
Post by Modsqwad »
almac wrote:it would be cool to just replace it with a illuminated compass like this:
Here they are. This was a hurry up job so I'm sure something slicker looking could be accomplished. It works good however and I'm
pleased with it for the present. Note the revolutionarily correct sunshade/anti theft device.
Andy
Post by Green1 »
