I went to a local shop and made an inquiry to install a remote starter, key lock and security system. I was asked a load of electrical questions such as, wire color combinations for locks, horn, ignition and the list goes on.
I was printed off a spec sheet for a 97 Montero (for example purpose only).
Does a similar spec sheet exist for the Deli?
Is the wiring diagram enough to help with this install?
Has anybody had problems with such an install?
Remote starter etc..
- White Mule
- Vehicle: 1991 Delica L300
Thanks,
White Mule
White Mule
- Profister
Re: Remote starter etc..
You deal with the wrong people; ask Falco or Butch for the right directions.
Sergiy.
Sergiy.
If you get to Vancouver, in North Van there is a place that will understand your van and set a remote up for you. If the people you are talking to say that it will cost more because of the RHD issue.... go somewhere else ~ they don't know what they are doing. Performance Car Stereo is where I went. I will recommend them any time. If you do come out here, give me a call and I will introduce you personally. Be well.
- White Mule
Thanks Falco.
Yes the second place I went to had zero issues and has worked on several JDM.
The price came in much better as well.
Thanks again and I may see you in September.
Thanks,
White Mule
White Mule
