Hi All.
I'm hoping someone can help me diagnose a noise in the front left wheel area of my Delica. It only happens when I'm turning left and that corner of the van is weighted. Sounds like a suspension thing...
Thanks in advance.
Scott
Suspension Noise
- Vehicle: '93 Exceed
Re: Suspension Noise
Hey there - your subframe bolts may need to be pulled, greased, and re-installed.
- fishslapper
- Vehicle: 1994 lwb l400
I would say just check all the subframe bolts and make sure they are tight !! this will solve the problem 99% of the time ! I have not heard of pulling and lubing them before........not that you should not do this....just news to me !
cheers isaac
cheers isaac
The Mighty Boosh !!
Thanks Guys. Much appreciated.
For a newbie, can anyone offer directions to the location of these bolts?
- fishslapper
use the search function ! There are posts with pictures and everything ! ............I think it is under "suspension clunk"
Or something like that. Sorry i can't remember the exact name to search for.
good luck
good luck
The Mighty Boosh !!
Check out "Delica Wiki" in the forum under "Delica Canada Technical" while you are at it. Much useful information including service manuals.
