power sunshades (crystal-lite roof)
- BCDelica
Well thank you for being what appears to be the first in Canada to tackle this problem, breadman referred to it as the holy grail of Deli fix's. And yes things sometimes go wrong with do it yourself projects, just yesterday evening I decided to tackle the leaky floor seam on my passenger side. Every thing was going quite smooth, I have done this to a total seven Delica front corners and felt pretty confident. Well I was little forceful on the top screw under the window molding and jammed the phillips bit into the inside corner, cracking my windshield a bit in the bottom corner. Was pretty chocked, blamed it on the new strength that's coming back into my right arm since my neck surgery.
Kev - you only hurt the ones you love, right?
Call me BCDelica-less-
