L300 Exceed - How to determine if it has limited slip diff?
maw
Vehicle: 1963 Unimog 404.1 & 1992 Delica
Post by maw »
Hi all,
What are some ways to determine if my Delica has Limited Slip Differential(LSD)? Can I tell by the VIN or any other version markings? I got under the rear axle and inspected the diff but did not see any markings or serials to hint at an open or LS diff. Any suggestions would be appreciated.
FYI, I have 1992 L300 Exceed, short roof with winter package. AFAIK, not jasper or chamonix model. I think I saw "P25W" beside the VIN tag.
I guess the tell tale way would be to jack it up in 2WD and see how the wheels spin in drive?
39Ronin
Vehicle: Mercedes Benz Gelandewagen 300GD
Re: L300 Exceed - How to determine if it has limited slip diff?
Post by 39Ronin »
Usually there is a sticker on the diff saying to use LSD diff fluid only.
sid
Vehicle: 1993 super exceed
Post by sid »
this one has been brought up many times. open the drivers door and look for the orange sticker with black japanese words at the bottom corner of the door. i believe its at the low corner of the door where your right hip would be when the door is closed. orange sticker means lsd. i even had it translated by a japanese student. thats what it says.
hope this helps sid.
jack up rear end
rotate one wheel
if both move in the same direction = limited slip
if one moves counter to the other = open diff
maw
Post by maw »
thank you. A few different options here, I will do all of them to make sure ;)
Find a patch of level wet grass, stomp on the accelerator, and if you get two track marks instead of just one - limited slip.
marsgal42
Vehicle: The Mighty Gumdrop
Post by marsgal42 »
This is what the limited slip differential sticker looks like.
Limited slip differential sticker.
LSD sticker.jpg (41.4 KiB) Viewed 4174 times
...laura
