- *Incredible rough colds starts on diesel even after purging the engine
*Even after starting there is hardly any power on diesel, once I warm the engine up a bit and can switch to Veg power improves dramatically, I'm guessing it has something to do with the two Aux fuel pumps I've added to the Veg lines
*Starts fine on diesel if I plug in the block heater for an hour or 2
My next option is to switch one of the Aux fuel pumps to the just before the IP supply so that it assists both diesel and WVO. The only reason I haven't done this before is because I was worried about hot WVO wrecking the pump.
Does it sound like a glow plug or IP issue? I have to take it up to CC Autos for a tune up this month anyway, but I was hoping to try to figure out the issue first and save Glenn some time.
