I had mine done at Quiet Muffler on kingsway like David's.northvanmatt wrote:hello I just had mine done at quiet muffler on broadway in burnaby. stainless steel went out the side with it and got the 2.5 inch pipe. All said and done just under 300$ took about 45 min and the van runs way way way better. I am blown away by how much better it runs.
They did a really %!*& job on mine.
I had to take it to another muffler shop to cut and re-weld because Quiet Muffler did such a horrible job.
They were not friendly and when I had problems with mine, I took it back and they tried to blame me for the rattling (which was their fault).
I would not recommend them.
See here :
http://www.delica.ca/forum/2-5-side-exh ... -2387.html
jfarsang wrote:I just got mine done at the same place, Quiet Muffler on Kingsway.
Mine came out to $369 tax in.
$70 MORE than David's for exactly the same thing.![]()
He said David's was an 'experiment' and that they charged less labour on his then what it should have been.
I needed it done (muffler was coming apart) otherwise I would have shopped around.
Anyways, the welds are 'o-kay'. Sloppy in my opinion.
I'm going to install a pyro probe up in there and will clean up the weld from the downpipe and eliminate the 2 - 2.5" diameter bottleneck at the flange when I have some more time.
Jesse
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
