I took the plastic covers off (it took me a few mins to realize they slide off
So, I removed 2 belts: 1 was cut and the other one (very thin belt) I cut myself. I wanted to cut another one that is still hanging but still looks kinda in good shape, so at the end decided to leave it there.
I think there are still 3 belts: 1 is good, 1 is hanging and the other one is still in place but it looks upside down (the side with teeth or whatever they're called is showing, and I think this side is supposed to be against the moving parts for friction purposes...)
So, could you guys please comment on the pics and/or give me advice. I turned the engine again and the white fan is moving, still making some noises, but I think this is because of the loose belt. By looking at the belts, I think the mechanic here in Calgary only replaced 1 and he left the others untouched. I might be wrong, but comparing the shape of the belt with yellow letters (see pics) vs the others, I can tell this is the only one that looks kinda new. I've had the van for 2 years, but I've only put 24,xxx kms on it, so the belt that is intact still looks in pretty good shape. (Just one comment about the yellow letters: in some of the pics the fan is moving, so the belt looks black with no letters, but in some of the pics where the engine was off, the letters can be seen)
But I don't know much about this, so I'm only speculating.
Regards and thx in advance for any advice. One final question: The mechanic is 30 mins away from my house, and I'm not sure if I can drive the van or not. Should I try to drive it or should I tow it to the mechanic?
Fabio
Calgary
