nice cheap turbo mod 4 L400
deligate
Vehicle: 95 super exceed l400
Post by deligate »
remove and replace the intercooler pipes with mandrel bent metal ones you can do in stainless
or just exhaust pipe with 3" of rubber over each end and 4 hose clamps
stops the hoses from contracting under load
or even cheaper but needs maitenence a zip tie every couple of cm apart on origonal hoses cuts down on lag get your self a unifilter $88.00 aud
i save bout 100km a tank since i got it
good luck
mick and the delig8ter
p.s. get yourself a good strong bash plate to protect your oil filter nothin worse being stuck in the middle of bum f@#k nowhere without a oil filter
L400 is HEAVY round the 2 tonne mark
Re: nice cheap turbo mod 4 L400
100km per tank that you save ?
A 20% decrease in fuel consumption by changing the pipes over the metal ?
Where's that fiddle ? :-D
deligate
Post by deligate »
unsure what your question is so i've answered the best i can
if you could make your question clearer for a slow aussie like me. i can answer more directly
no by fitting unifilter i get a fuel saving of 20% its not a decrease in consumption in my book (unless your backward)
metal intercooler pipes cut down on lag
sorry for any confusion
just trying to help
MardyDelica
Post by MardyDelica »
Mick,
your australian slang accent some time confuse us. its mix witl british & australian.
will get used to it later. sorry no offense . its nice to know
Cheers;
bryanc
Vehicle: 91 ecxeed mtl gry over black
Post by bryanc »
Mardy does this make sense to you ? if so can you do it ? and if yes how much would it cost ?
Thanks , Bryan
MardyDelica
hi, i dont know yet.
i know my spacegear has this pipe attached on it.maybe i can buy this for you in japan. no problem. see attached my spacegear pictures.
deligate
Post by deligate »
mardy your pipes are great when it arrives you should get them copied (minus blow-off valve)
it goes psst when you change gears
the blow vave is designed to realease under extreme load (during realease of accelerater) to prevent the turbo fins from stopping suddenly by realeseing the back pressure created by acceleration also to prolong the life of the turbo
however unless your driving like a maniac all the time not really nescersary (personal opinion )
i hope i didn't balls up this explanation
if ya want to see how much the standard pipes contract while acelerating get some one else to sit in drivers seat and rev (watch em move )
hope this helps
happy easter :-D :-D
bryanc
Post by bryanc »
That sounds like a nice little mod , Mardy any chance you can do as Deligate suggests and copy those ?
ps : my wife is dying to know when her Deli is arriving
Thanks , Bryan
MardyDelica
hi, it will arrived next week.
cheers;
madmazda
Vehicle: 1994 l400
Post by madmazda »
since I'm a plumber I made up some out of copper tubing and fittings.....I'll post pics if I can.... what a difference it made.... pulls way better on the highway when passing....
Return to “L400 Technical”
