2x Rear Shackle 2" lift
2x Front Spacer - Tapered Balljoint 1"
4x Tcase Spacer - 1/2" Transfer case drop down
4x 3/8" Large washers
10x Metric fine bolts
10x Plated washers
6x Plated Stover nuts
2x Rear stock shock adapter blocks
2x Plated metric nuts
2x Ext Grease fittings
- Shackle Kit includes:
- 3/8" reinforced/welded steel / Gunmetal Gray Eurathane paint - chip/corrosion resistant
- 2x 3/8" Large washers
- 6x Bolts & stover nuts
- 2x Rear stock shock adapter blocks
- 2x Plated metric nuts
- Ball joint kit includes:
- 2x Tapered Balljoint 1" (Polished stock)
- 6x Plated Metric fine bolts
- 6x Plated Washers
- 2x Longer grease fittings
- Transfer case drop down kit includes:
- 4x Steel spacers
- 4x Plated Metric fine bolts
- 4x Plated Washers
All hardware (bolts/washers/nuts) metric size/plated Grade 8 *
These kits are available and will continue to be in production for the L300.
The price point is fixed at $350 per L300 kit.
The entire kit is fabricated in-house (one shop) by Jesse Smith (long-term metal fabricator) to keep costs down, for the exception of hardware and shop materials.
This lift will provide a firmer and more stable ride on your Delica.
** Recommended longer shocks :
- 2" longer stroke on the rear
- .5 - 1.5" longer stroke on the front
** Recommended wider rims with larger tires :
- Wheel/Rim size : 15x7 or 15x8 with 3.75 to 4 " backspacing
- Maximum Tire size : 31x10.5x15
** Not included with lift kit.
Shipping options :
- local pickup $0
- Greyhound depot service across Canada $25
- Overseas $ please contact for quote
We stand behind our product and any questions/concerns will be dealt with direct with the fabricator/manufacturer.
Contact :
Myself or jfarsang via PM or :
Parkside Auto
Jesse Smith 604.309.7718 (owner/fabricator)
Jesse Farsang 778.549.4542 (emply)
parksideauto@hotmail.com
Installation & custom work available. Please contact for details.
Lift kits Available :
Delica L300 2" Suspension Lift (1986-1998 GenIII)
Coming soon... Delica L400 2-5" lift kits (1994-1998 GenIV)
Pajero/Montero SWB/LWB 1-3" Suspension Lift (1982-1990 GenI)
Pajero/Montero SWB/LWB 1-3" Body lift (1982-1990 GenI)
Pajero/Montero SWB/LWB 2" Suspension Lift (1991-1999 GenII)
Pajero/Montero SWB/LWB 2.5" Body lift (1991-1999 GenII)
L300 lift kit images :
Before Lift :
After Lift :
* Grade 8 Bolts: Strength and Durability
The factor that makes a grade 8 bolt different from a lower grade bolt is its preload strength.
The most useful areas for grade 8 bolts are for military, aerospace, or marine related mechanical applications where high stress and strong load bearing pressures are a major factor.
The off road vehicle market also has a need for grade 8 bolts for the same reasons. One thing to keep in mind is that it's almost always a safe bet to go with the highest grade of bolt you can when in doubt. Manufacturers may recommend a grade 5 or grade 6, but it never hurts to go with higher quality materials. The worst that can happen is that you paid a little more for the peace of mind.
