Snake oil or a miracle product.
http://www.dieselsecret.com/index.html
Call me BCDelica-less
Call me BCDelica-lessDon't I remember Green1 talking about this stuff except he sounded like he understood it all?
Well, it just was too good to be true and just had to try it and see what it says.
Basically the manual tells you to buy a Walmart plastic garbage can a couple of pumps and a couple of household water filters, hoses and fittings. Install a Goldenrod filter in one for water removal and wa-lah your system is ready. Actually you also add Kerosene (10% ratio), unleaded gasoline (5% ratio), some Diesel-Kleen+Cetane boost and the magical/miracle potion (DSE) and then pump in your tank. Its pink in color and smells somewhat like paint thinner.
I have a friend who is a lab rat and will take it in for analysis. Out of curiosity, I'm going to mix a small batch up and see how it does in the fridge and then the freezer. I'm still scared to put it in my 2000 Dodge Cummins. It also has a chart stating that it is good to 30 degrees. Add 5% more kerosene for every 10 degrees colder. Blow is the mixing ratio, you guys are the gurus out here. What's your opinion?
20gal filtered WVO, 2gal Kerosene, 1gal unleaded gas, 15oz Power Service+Centane boost additive, 3.5oz of DSE mix slowly for 5 minuets and put it in the tank.
Q
