Hi again, just wanted to give an update on tanks.
When we looked into it further, the tank capacity was going to be less than hoped, and it's quite an expensive tank to build, for the 45 litres or so we'd end up with. Not really worth it, as it turns out....like most people, I want more capacity, and that 100+ litres,down low, at the rear, sounds good for those long trips, and for traction in the winter (keep it full, of course, as much as possible). Basically, if you are interested, the idea was to remove the spare carrier and then build the tank such that the spare could be fitted into a recess in the underside, with a hole, rod, carrier assembly to hold the tire and rim up into place.
So, for my own van, I will be using the much larger capacity tank as done for the one shown on our home page, which is about 3" lower than the existing spare, and I might lift the van and put on the larger tires at some point if I decide it's needed)
Then either put the spare on the front (move the bars forward and put in behind the fog lights) or just put the spare in the back in a plywood cubby that'll go in with the rear seat tumbled forward. That will allow me a flat loading surface above the spare (which will allow me to carry 12 filtered cubies of WVO). That, and a funnel, and I can refill the tank very easily, through the floor filler, even in the pouring rain (hatch overhead).
No pump, no hoses, and I can leave off the empties at the recycling places as I travel and gain interior space along the way (Starting off with clean ones gleaned from the restaurants, and be sure to leave the cardboard sleeves on - they add a lot to the strength!)
That will give us good range for a planned trip up to Rupert, Haida Gwaii, the Island, and back home, this summer.
New PlantDrive.ca Delica tank design leaves spare alone.
PlantDrive
- Vehicle: 1991 Delica
Re: New PlantDrive.ca Delica tank design leaves spare alone.
Post by PlantDrive »
Edward Beggs
PlantDrive.ca
Salmon Arm BC
plantdrive.ca@gmail.com
PlantDrive.ca
Salmon Arm BC
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
