Plugs (spark and frost)
Hello
I hope I've posted this correctly!
I was wondering about what size (and recommendations) for new spark plugs.
Also, has anyone installed a block heater? I've checked out a Webasto heater, but it's too pricey. Apparently if I have the frost plug diameter I can purchase something off the shelf, but, I think I also need a heater that has the correct angle.
Thanks for your help.
Marc
Marc
- PcSpecialist
fastbmw7
argo
- Pete and Jackie
Spark plugs
Dont forget to water the compass rose and grease the loran bearings!!
crushers
- Vehicle: Subaru Sambar SC
i recommend the lower rad hose heater over the POS circulating heater.
i installed a wabasto in one of the Delicas and the lady loves it.
i would go to a manual glow system, easy to do and you do not have to worry about the super glow system crapping out on you.
make sure you check the muffler bearings on a regular basis, if they go it can cause some real damage.
these are particularly problematic on the diesel systems. :D
http://www.luxuryimports.ca JDM imports
http://www.crushersrule.com restorations and trip reports
http://www.luxuryimports.ca/faq/importinfo.php import your own Cruiser
http://www.ivoac.ca separating the rumours from the truth. join today
argo
crushers
sorry, Peice Of S**t...
every circulating heater i have installed in the last 2 years has developed leaks in the housings plus they don't work as good as a lower rad hose heater...
argo
What particular brand have you been using? Too bad it took you two years to figure it out
Perhaps it is a case of sematics, but I reckon all remote coolant heaters circulate coolant by acting like a thermosiphon.
I installed one on my FJ40 quite a few years ago and never had any trouble with it.
If you can configure any remote cooant heater element to mount underneath your battery tray, you have the added benefit of a slight increase in the ambient air temp around your battery.
crushers
only since i started bringing the Delica units. there was barely any room to mount them up and then after a few months the buggers would start leaking
"i want to exchange this under warranty"
"no problem, we ahd a bad batch"
okay. then the new one start leaking with in the year...the customer would call after a few months and let me know "i have a wet spot"
hence the swap to lower rad hose...or better yet the wabasto...
i should post up shots of the wabasto install i did...very nice and clean...
Thomas Porter
Wabasto.
Yes in deed. Post the pix Crush.
I have to do this install soon.
Thomas
P.S. Coming to Delica 2008 in Banff?
Thomas
Population Density; One person per square kilometre. Just the way I like it...
crushers
i tried to post pics but this forum is slightly different than the others i frequent and i am having a hard time figuring it out...
Delica 2008? never heard about it...
Adrock
