I need a new or slightly used Accelerator cable, mine has broken on both ends and is now too short. Does anyone know the part # for it?
freezebomb
I need a new Accelerator cable for Delica Exceed
- Vehicle: 1990 Delica Exceed
- TardisDeli
Re: I need a new Accelerator cable for Delica Exceed
Hi, Not sure where you live as your profile is incomplete.
But if you PM Private Message to John at Rocky Mountain Import (PM Id is RMI) he will probably have a new one he can courier to you via Greyhound. Glen at CC autos in Coombs (PM is ccautos) may have a used one, he has the best selection of used parts. Or if you are in the Vancouver area, call Mardy at Amazing Autos (MardyDelica is PM ID), or call Butch at CVI Automotive repairs in Richmond.
If you need more ideas, or if you don't live in BC, then give more info in your reply and we can give you more names.
Good Luck, Christine.
Christine
- ccautos
- Vehicle: 92 Delica SE
There are two different cables used on Delicas depending on the length of the throttle lever on the injection pump . I have both used in stock at $45 each. Thanks, Glen
