quick question...
i am trying to find a trailer to tow my van and i found a two wheel dollie. And since the van is 500kms from where i am could someone please confirm the rear wheel base from centre to centre is 138 cms. I got this figure from one of the manuals on the site but i am not sure if i am reading it correctly.
Thank you.
wheel base
Dewy
- Vehicle: 92 Super Exceed
Re: wheel base
Wheelbase (front to rear / axle hub to axle hub)
2235 mm
223.5 centimeter
88 inches
Delica L300's have a very short wheelbase for the type of vehicle.
Great for offroading but sketchy at high speeds when sliding.
2235 mm
223.5 centimeter
88 inches
- konadog
- Vehicle: 1992 GLX L-300
Re: wheel base
I just meassured from the center of the back tire across the bus to the center of the other back tire as about 138cm.Dewy wrote:the rear wheel base from centre to centre is 138 cms.
Re: wheel base
Thought you meant wheelbase not width
138 on mine as well hub to hub
Dewy
Re: wheel base
Great ...thanks.
