I need Pajero parts. My slip splines on where the rear driveshaft goes into the transfer case are worn. These may be the same parts as delica but I am not sure. Any suppliers out there have this part? Mardy? CCAutos? rockymountain imports?
Gen 2 two door pajero 5 speed.
pajero parts
- MardyDelica
Re: pajero parts
hi, i think same spline but the lenghtis different measure it & send me a picture spls if you have time. i do have some of those parts.
let me know.
cheers;
mardy
let me know.
cheers;
mardy
bae146
Re: pajero parts
There is also a bushing in the tailshaft housing. The sleeve and the bushing are 0.010" different in size. There are no wear marks on the sleeve. So the bushing is worn as well. The bushing will be a mitsubishi item only I think, as it has helical grooves on the inside for oil. I have heard that the delica bushing is shorter but the same diameter.... I will be in Vancouver on monday Mardy. I am supposed to get my new windshield installed on tuesday, not sure if that will happen but I will be coming to see you for parts to solve this vibration. Unfortunatly I have to bring my wifes car. I will bring my worn parts with me. Even better than the picture. Can I come see you on tuesday morning? What time works for you?MardyDelica wrote:hi, i think same spline but the lenghtis different measure it & send me a picture spls if you have time. i do have some of those parts.
let me know.
cheers;
mardy
- MardyDelica
Re: pajero parts
hi, no problem,
just call me,tonight snow already come down. pls drive carefully from alberta. i think it will have big snow.
pls do drive with care. lot of crZY DRIVER OVER THERE.
cheers;
cheers;
bae146
Re: pajero parts
MardyDelica wrote:hi, no problem,
cheers;
Yup that is the worst part. The lower mainland has never seen so much snow and I have to leave the pajero at home. I will call you when I get to vancouver on monday. I will come see you on tuesday
