The Super-select transfer case has two 4H settings, one with the transfer case differential free (4H) and the other with it locked (4HLc). That is the locked/unlocked I was referring to, independent of whether the hubs are locked or not.konadog wrote:Well, maybe just a liiiitte fastermarsgal42 wrote:I've never exceeded about 50 klicks in 4WD. Super-select vehicles are different in this respect, and can travel at top speed in 4H unlocked.Those main-line gravel roads are pretty fun in 4 high
But the last bit of Marsgal42's quote leaves me confused - If the tranfer case is set in 4 hi but the hubs left unlocked, won't the links to the front hubs simply spin uselessly and poise no threat to the gear on a grippy surface? I totally get leaving the hubs locked but not engaging the tranfer case until reaching a slippery section, but not the other way 'round.
I bought a copy of the JPNZ L400 owner's manual, just for fun, and it discusses the transfer case settings and when to use them at some length.
...laura
