its pretty apparent though, that the one of the long pipes is fuel in and out. im pretty sure there is a siphon between the tanks and perhaps the other pipe plumbs them together
Image Hosting
Image Hosting
Image Hosting
Image Hosting
Call me BCDelica-lessYes, use one top line as a return and the other top line either as a vent to a check valve (ask Collin - also ask how my old computers are working) or to the top of the tracker tank. You should still use a one way check valve off any one tank, mounted nice and high up under. Can't remember where the float valve was plumbed to?after oil wrote:so what about the return from IP?
im adding the third tank, and plumbing it to rear stock tank, do you think i need to concern myself with the pipe from the air float to the front tank? plug it? keep it attached to the front? make a connection for it in the rear?...
No, set up properly it'll well keep level.do i need to return veg to both tanks?
It's all good.now where getting into the realm of the WVO forum, but i figred the pickup questions were suitable for the tech forum
