im installing a WVO kit and the wiring requires one wire to go to "N on contact remains postive"
can anybody tell me where i can wire to to achieve that? preferably somewhere in the battery compartment..
its a little vague for me?
suggestion for "N on contact remains postive"
- after oil
- Schwa
- Vehicle: 1992 Delica Exceed
Re: suggestion for "N on contact reaminsa postive"
Pretty hard for my brain to decipher that at the moment, perhaps I can help you figure it out if you tell me what it is connecting to and / or some more info about the component being connected.
- after oil
Re: suggestion for "N on contact remains postive"
the component is the "brain" of my wvo kit. when the key is turned it turns the brain on. seems simple. heres the diagram, look by the key.
Image Hosting
Image Hosting- Schwa
Probably wants the "engine on" circuit then... Dunno if that comes near the battery compartment or not, but you can access it near the steering column or in the center console feeding the power window switches.
They worded it kind of funny. It looks like they meant to say "12v in run and in start" meaning when you turn the key on, it is 12v, when you go to crank, it should still be 12v and not drop out (like your accessory circuit does).
- marsgal42
- Vehicle: The Mighty Gumdrop
Why not ask the people who sold you the kit?
Our Delicas have a lot of oomph in their batteries and guessing wrong could have unfortunate consequences. Besides, you shouldn't have to guess.
...laura
...laura
- after oil
center console is close enough, ill check those wires out there.Schwa wrote:Probably wants the "engine on" circuit then... Dunno if that comes near the battery compartment or not, but you can access it near the steering column or in the center console feeding the power window switches.
i did however notice a white plug with a whole bunch of wires inside the battery compartment, on the outside wall of the van. ill have to look around to see what those wires are...
thats what i believeEricN wrote:They worded it kind of funny. It looks like they meant to say "12v in run and in start" meaning when you turn the key on, it is 12v, when you go to crank, it should still be 12v and not drop out (like your accessory circuit does).
i have asked, but its slow communicating with the guy. he lives in bulgaria and internet is expensive there. i call his cell and he goes to the phone-eteria when its AM my time, but he usually misses me.marsgal42 wrote:Why not ask the people who sold you the kit?
...laura
- after oil
i looked though some notes i took from a phone conversation, and sure enough, the answer to my question was there...and its what we thought, powered when key is on. i found the blue wire in the centre console and powered it from there. thanks for the tip on that!
