FOR SALE 1993 DELICA EXCEED
fivestarauto
Vehicle: Delicas
Post by fivestarauto »
8-) 1993 DELICA EXCEED super nice condition!! 8-) 158,000 kms, preventive maintance done such as: oil filter, new oil, air and fuel filter, timing belt, balance belt, and drive belts, timing belt tensioner kit, front engine oil seal set, valve cover gasket set, water pump, thermostat, radiator cap, upper and lower rad hoses, hose clamps, recored radiator, remove and reseal fuel injection pump, DOT headlamp set, DRL module, headlamp bulbs, front shock absorbers, front sway bar bush kit, front brake pads, front brake rotors, front outer tie rod ends, delica ehaust system, rear sway bar links, engine mounts, transmission mounts, wiper blades, wet batteries, ATF transmission fluid, antifreeze, totalling $4,858 plus new ten ply nexon tires. We also go right through our vans as far as detailing! we use an orange organic citrus cleaner which also takes all the nicotine out of the roofs interior to make it look and smell bran new....
price is $ 13,995 any more information please feel free to contact us at 250 248 8311 or our website http://www.fivestarautosales.ca
