Question on ProComp Shocks
- JMK
- Vehicle: 92 Chamonix
After reading the previous posts, I ordered a set of ProComp ES9000 shocks: 913515 and 919520. They cost $69.67 each. I thought I remembered reading they were adjustable but I must of misunderstood and probably mixed them up with Rancho's? I just pulled them out of the box and obviously there is no adjustment. I presume they are still one of the better shocks to use for the Deli?
- mdrive
Re: Question on ProComp Shocks
No they are not adjustable but good shocks. We sell them for $240 with rubber boots if any one needs more.
- JMK
Sounds like a good price, I had to pay an extra $5.23 for the boots as well.
I went with the ProComp because I though I read that if you go with Rancho's you must use the conversion kit, but then they are too long, so you have to make up an adapter to do it properly.
- EnviroImports.com
the procomps are good shocks, and the ranchos are good, the adjustable ranchos ar "9000" and can be adjusted with a dial OR a on dash contoller with a Very tiny compressor like i have in mine, but the rancho 5000s are a easy fit in the delica also, Just because some are to long doesent mean they all are, I just put rancho 5000's into a customers van and they work great, Mind you we did put in ones that are designed for a slight lift as we are doing the lift on it in the next couple weeks
I like that the ranchos come with the 12 month warrantee
