1993 Delica Super Exceed 151,000 kms. In-Transit (Green w/ Gold color; No Rust)
Price: $ 10,400
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
Pls see our feedback on us, Thanks:
http://www.delica.ca/forum/delica-deale ... -3086.html
Will do the ff. service & Details of this Delica:
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new Japan made water pump, new bearings, 4 new seals (Mitsubishi), New thermostat;
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change filter, clean transmission pan;
4.) New depot headlights with 4 new osram bulbs (Made in Germany);
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) 4 New pro-comp shocks 9000 series;
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) LSD Differential;
12.) 2 batteries, designed for Winter package;
13.) No rust on the roof;
14.) Runs very good & stable;
15.) 7 passengers;
16.) All the shades work
17.) We reseal the front panels on all our Delicas ,so you won't have to worry about floor leakage.
1993 Delica Super Exceed 151,km(green/gold). *SOLD*
- MardyDelica
- DSCN4931.JPG (86.99 KiB) Viewed 3320 times
- DSCN4935.JPG (83.11 KiB) Viewed 3318 times
- DSCN4937.JPG (85.33 KiB) Viewed 3319 times
- DSCN4939.JPG (78.24 KiB) Viewed 3317 times
- DSCN4945.JPG (82.59 KiB) Viewed 3313 times
- DSCN4951.JPG (76.67 KiB) Viewed 3309 times
- MardyDelica
Re: 1993 Delica Super Exceed 151,000 kms(green/gold). Arrived
Delica arrived.
nice condition, all shades works, runs very well.
pls call me if you need more info;
cheers;
cheers;
- MardyDelica
Re: 1993 Delica Super Exceed 151,km(green/gold). Arrived $10,400
Hi, Future Owner did give deposit.
thanks
thanks
- MardyDelica
