I picked up Andrew's kit and studied the manual for the rest of the night... In the morning I went to my friend's place and jacked up the back end to do some test fitting...
Looks like the heater in/out ports interfere with the hitch, the circles show where they would have to be to fit, but would still be extra difficult to install. Better to have them come out towards the front. Hitch has to come off to get the sway bar down for drilling the bracket mounts.
The exhaust has to be re-routed above the spring, or side-exit for the tank to fit.
Side exit wins for a cheap, quick 'get on with the install' hack.
Cutting some metal for the valve bracket
Finished mounting the filter and valves:
Finished mounting the tank (still needs bracket painted & filler hole drilled/cut in floor):
Hose routing:
Splicing the heater hose: (messy job!)
Plumbing the fuel lines:
Electrical next!
Call me BCDelica-less
