1993 Delica Exceed 133,000 kms(Brown). SOLD
- MardyDelica
1993 Delica Exceed 133,000 kms. In-Transit (Brown color; No Rust)
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
PLs see our feedback on this topic, Thanks:
http://www.delica.ca/forum/delica-deale ... -3086.html
Will do the ff. service & Details of this Delica:
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new Japan made water pump, new bearings, 4 new seals (Mitsubishi), New thermostat;
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change filter, clean transmission pan;
4.) New depot headlights with 4 new osram bulbs (Made in Germany);
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) 4 New pro-comp shocks 9000 series;
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.)Delica has aluminum roof rack & ladder
12.) 8 passenger
13.) Clean car
14.) No rust on the roof & under
15.) Runs very good & stable;
16.) We reseal the front panels on all our Delicas ,so you won't have to worry about floor leakage.
17.) will change front rotor , pads or shoe if it needed & repack the front hub & bearing.
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
12.) 8 passenger
13.) Clean car
- DSCN5197.JPG (91.19 KiB) Viewed 9502 times
- DSCN5202.JPG (91.29 KiB) Viewed 9501 times
- DSCN5216.JPG (93.9 KiB) Viewed 9498 times
- DSCN5223.JPG (84.48 KiB) Viewed 9496 times
- DSCN5227.JPG (89.6 KiB) Viewed 9496 times
- DSCN5230.JPG (75.54 KiB) Viewed 9493 times
Re: 1993 Delica Exceed 133,000 kms(Brown). In-Transit
I like that color scheme.
- MardyDelica
Thank you, Jessie,
Yes, it a nice looking Deli. No rust at all,
Pretty neat.
Cheers;
Pretty neat.
Cheers;
- MardyDelica
Re: 1993 Delica Exceed 133,000 kms(Brown). ARRIVED
Hi, Delica arrived,
car arrived in mint condition no rust Under drives really well.
will do all full service. call me anytime
Cheers;
Cheers;
madmazda
- Vehicle: 1994 l400
Re: 1993 Delica Exceed 133,000 kms(Brown). ARRIVED $10,800
is this still for sale????
- MardyDelica
hi, yes, but the roof rack & ladder is sold , i have to change the picture now sorry for that.
but this unit is clean no rust under & inside is clean. let me know if you want it. call me pls\
thanks
thanks
madmazda
I did call the other day but you seem buisy...I'll give you a bell later this week as I have many q's as do you ship to alberta....PM me if you like...Rob
- MardyDelica
Hi, Sorry i miss your call, just busy one man alone. call anytime even after 6:00 in the afternoon its o.k.
again i apologized. will wait for your call, Cheers;
- konadog
- Vehicle: 1992 GLX L-300
Me toojfarsang wrote:I like that color scheme.
madmazda
hey no problem...I know how it is....I really like this one so I'll give you a bell this week....
madmazda
can you get another roof rack and ladder for this one????
- MardyDelica
hi, i will try, call me anytime pls.
cheers;
cheers;
madmazda
OH I forgot to ask...does this one come with a LSD rear end????
- MardyDelica
no it does not have Lsd. sorry but this one under no rust like new
cheers:
cheers:
