1992 Delica Exceed 161,000 kms * SOLD *
MardyDelica
Post by MardyDelica »
1992 Delica Exceed 161,000 kms. In-Transit (Grey color; No Rust)
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
Will do the ff. service & Details of this Delica:
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new Japan made water pump, new bearings, 4 new seals (Mitsubishi), New thermostat;
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change filter, clean transmission pan;
4.) New depot headlights with 4 new osram bulbs (Made in Germany);
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.)
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) No rust in the roof & under
12.) Runs very good & stable;
13.) 7 passengers;
14.) All the shades work
15.) We reseal the front panels on all our Delicas ,so you won't have to worry about floor leakage.
MardyDelica
Re: 1992 Delica Exceed 161,000 kms(Grey). Arrived
HI, This Delica has just arrived
Cheers;
MardyDelica
Re: 1992 Delica Exceed 161,000 kms Deposit * On Hold *
Hi, this delica is on hold, have deposit on it.
thanks
MardyDelica
Re: 1992 Delica Exceed 161,000 kms * SOLD *
Delica is Sold:
Thank you
