Spoiler clips?
Spoiler clips?
I'm looking for at least two, intact clips which hold the spoiler onto the rear gate. If you've removed your spoiler and don't intend to replace it, I would appreciate a PM so we can discuss how I can take the clips off your hands (maybe the exchange of goods).
Crappy cell phone picture
I removed my spoiler in order to repair it, and one of the clips broke and another had difficulty with the set screws. Considering these clips are nearly 20 years old, I thought I was doing pretty good.
MardyDelica
Re: Spoiler clips?
Post by MardyDelica »
Hi, paul, i have same problem.
i will check tomorrow if the place is open.
i see similar to that clip,
just maybe need fabrication let you know the outcome.
cheers;
mardy
Re: Spoiler clips?
No longer to worry, I made some in my garage. Stainless steel, a hammer, an anvil, a drill, tapping set and voila!
MardyDelica
Re: Spoiler clips?
Hi, wow, good for you paul, can you pls send us the picture when you have time pls. mind is also rusted. i need to do modification, i havent been to the other place i mention is see sometine look alike.
cheers;
Re: Spoiler clips?
If you can manage to get an old clip off without busting it in half (I got three off intact, but the fourth didn't want to play nice), just replicate them. I used some flat strips of stainless steel, fold it into the shape of a 'U', cut it to the lengths you want, drill the holes, tap them, and there you go. The hardest part is the bending - would be best if you could get a metal shop to fold up a one or two metre length, and then you cut it up to the appropriate short lengths.
MardyDelica
Re: Spoiler clips?
i see, thank you, Paul,
cheers;
