Inclinometer Repair
The Pinkfingers
Vehicle: '94 Exceed
Inclinometer Repair
Post by The Pinkfingers »
For some reason our inclinometer decided to get stuck at an odd angle. Tried "tapping" it loose (i.e. giving it a slap on the top of the console). No go.
Any ideas how to un-stick it?
Thanks. :-)
Last edited by The Pinkfingers on Fri Jul 04, 2008 4:11 pm, edited 2 times in total.
snelson
Vehicle: 92 Delica Exceed
Re: Inclinometer Repair
Post by snelson »
Hey Pink - probably the easiest thing is to just take the thing apart.
Really easy - there's a small plastic flap on the bottom/front that you can remove with your fingers.
Then its just a matter of putting a screw driver to work and pull everything apart, then once you're in there you can determine if yours has leaked out all it's fluid, or if you just need to 'wiggle it'.
Steve
josh
Vehicle: L300 poptop gasser
Post by josh »
Are you sure you don't have two of your wheels parked up on a curb? 8-) (oops, am i supposed to be helpful?)
Josh
The Pinkfingers
Vehicle: '94 Exceed
josh wrote:Are you sure you don't have two of your wheels parked up on a curb? 8-) (oops, am i supposed to be helpful?)
Josh
Doh! *smacks forehead*
The Pinkfingers
Vehicle: '94 Exceed
snelson wrote:Hey Pink - probably the easiest thing is to just take the thing apart.
Steve
What plastic flap??
I pulled at the rubber cover and it came off with an unfortunate ripping noise, and left some of its foam behind. So now the unit looks like this:
This is without the rubber cover.
With the rubber cover above:
I still don't see a plastic flap, and now I have to re-glue the cover...
A little help would be greatly appreciated. Thanks. :-)
Adam
Re: Inclinometer Repair - EDIT: did I just screw up?
Post by Adam »
The plastic molding is at the base of the pod and covers up the screws you need to undo to remove the pod.
Here are some shots of mine partially disassembled:
snelson
Post by snelson »
:shock:
Holy Jebus - sorry Pink!!
I guess I should have written GENTLY remove with your fingers... LOL
At least you should be able to just glue that back.....
The Pinkfingers
Vehicle: '94 Exceed
Well crap.
OK - so how do I get the plastic molding off?
The Pinkfingers
Vehicle: '94 Exceed
snelson wrote::shock:
I was gentle actually. But it was a hot day so it was probably already pretty gummy. Oh well. Live and learn. 8-)
snelson
Post by snelson »
Mine just came off with gentle pressure from my fingers. There's only small little clips holding it in place. ONce it's off you'll see the little screws....
The Pinkfingers
Vehicle: '94 Exceed
snelson wrote:Mine just came off with gentle pressure from my fingers. There's only small little clips holding it in place. ONce it's off you'll see the little screws....
Yep. Got it off. And it looks like the inclinometer is without fluid. I wonder if I need to buy a new unit?
EDIT: scratch that. When I hold it over my head I see the fluid... and little pieces of plastic floating around in it. Looks like something broke all right, but I have no idea how.
jwfchase
Vehicle: '92 Super Exceed
Post by jwfchase »
The Pinkfingers wrote: What plastic flap??
Am I a bad person because I couldn't help myself laughing out loud when I saw this picture? Sorry, just looks like something I might've done myself...
The Pinkfingers
Vehicle: '94 Exceed
jwfchase wrote:Am I a bad person because I couldn't help myself laughing out loud when I saw this picture? Sorry, just looks like something I might've done myself...
My wife split her sides laughing. Though at first I came inside and she said, "How's it going?" And I replied, "You can go and look if you promise not to get mad." And she gave me that look.
But I glued it back on and so it looks like it did before. No worries. Inclinometer still broken though.
Sorry, I giggled too, as I thought "Don't pull on THAT part! No, the OTHER part... never mind."
But it does look like you actually got it apart the right way now. If you do refill it with fluid, use something like a light mineral oil. Problem is, if it leaked out in the first place, it probably was the seam around the edge the let go and not the filling port.
Good luck...
Post by Green1 »
