Single -> Dual Piston brake upgrade + auto -> Manual hubs
jwfchase
Vehicle: '92 Super Exceed
Re: Single -> Dual Piston brake upgrade + auto -> Manual hubs
Post by jwfchase »
Jessie,
Now you can do this: !!!
http://www.youtube.com/watch?v=dHRgVvAO8Pw
Bruce,
I'm sure I can hide a set of manual hubs in my luggage, coming your way July 26...
See you then!
David
Mystery Machine
Post by Mystery Machine »
delicat wrote:Bruce,
See you then!
:twisted: :twisted: :twisted: :twisted: :twisted:
Sounds like a plan!
Do you want paying in advance?? let me know?
Also - thanks to Jesse and Jaz for the offers of getting me some hubs too. Sounds like David's idea might work out best though....no customs payment and a good excuse to meet a Canadian Delica fan on British soil :)
Thanks again guys.... 8-)
Mystery Machine wrote:Hi Jesse,
Sorry if this is a daft question, but why do you need to remove the bearing lock plate and adjuster plate to fit the manual hubs?? The rest of your instruction makes perfect sense to me having removed the auto hubs too many times to mention....but surely the new hubs just replace the old ones, so the bearing is left untouched? Am I missing something obvious? (PLEASE put me out of my misery! :-D )
Bruce. It was late, I was typing... :? :-D
Edited for the proper process. 8-) :M
Mystery Machine
jfarsang wrote:Bruce. It was late, I was typing... :? :-D
Ha ha...I know that feeling all too well!
Sometimes my brain and my typing finger get all confused and start to argue. Throw in a dose of alcohol and tiredness and all hell breaks loose! :-P
The Pinkfingers
Vehicle: '94 Exceed
Post by The Pinkfingers »
With manual hubs, when you lock them in 4x4, does the dash light still come on?
bae146
Post by bae146 »
The Pinkfingers wrote:With manual hubs, when you lock them in 4x4, does the dash light still come on?
If it is like the pajero the light is driven off the front axle engagement, so it doesn't matter what the hubs do.
Bingo :-D
Well we finally got the hubs changed over to the Superwinch manuals. No, I didn't attempt the project! Hazel was in to ccautos for a new windshield and motor mounts so we had the pros do the switch. Thanks for the parts number and connection jfarsang - a big help. I want to bring up this post again to point out that some delicas come with permanently locked hubs. Ours did and hence the desire to switch them. The new manuals are great - with the deli ya don't even need to get out to switch them; just open the door and reach down! :M :-D
If your hubs look like this they are permanently locked and so should probably be switched for auto lockers or manuals
The new manual lockers don't look as good, but hey, not bad, and function before form, right? :?
manual hubs.jpg (52.17 KiB) Viewed 13055 times
Schwa
Vehicle: 1992 Delica Exceed
Post by Schwa »
Went into Lordco today to order me some brakes, but all they could find was pads... I gave them the part numbers Jesse posted but the guy said those part numbers don't exist in their system, so he looked up a '92 Mitsu. Montero and still couldn't find anything but pads. Will give NAPA a try tomorrow, but I have a funny feeling they'll have to be special-ordered in since the vehicle was never sold here.
Napa will have them for sure.
You can cross reference the Canada and US Napa part #'s .
Not sure about Lordco but Napa has the 92 Montero Sport brakes
Make sure you get semi-loaded calipers that come with the mounting brackets and pins.
For calipers, you can go any brand.
For rotors, I highly recommend Raybestos PG (professional grade). They cost a bit more but trust me when you see the difference you'll get them.
Pads are personal preference. Don't get the cheap one's. Metallic or Ceramic and a good grade.
The front brakes on these puppies are extremely important compared to mid/rear engine vehicles. :M
Schwa
Post by Schwa »
I was hoping to go with Lordco because a friend of mine has an account, so I won't get completely hosed at the till, NAPA I have no connections, so I'll probably be paying double what you paid, lol.
I think I have a seized caliper, one side one pad is gone (started grinding today) all other pads look fine, but the left disc is badly pitted and seems warped. I tow a boat with an old trailer that has no brakes, so I really should upgrade to the bigger brakes anyhow.
Schwa wrote: I tow a boat with an old trailer that has no brakes, so I really should upgrade to the bigger brakes anyhow.
Yes !
Schwa
Post by Schwa »
Is there a difference between the 1989 / 1992 rotor?
92+ should be thicker BUT I may be wrong. I would have to take a micrometer and check (I don't have the old ones anymore)
