Removing Stickers
The Pinkfingers
Vehicle: '94 Exceed
Re: Removing Stickers
Post by The Pinkfingers »
FalcoColumbarius wrote:One thing you can do to remedy the imbalance of the stickers on one side of the tailgate, Pink ~ is stick a "[/color]DELICA" sticker on the other side, which is what I did ~ and it so happens that I have one or two in stock.... smiles.
I'll buy one from you. I'll put it where the BF Goodrich sticker is now, and move the Japanoid to above the license plate.
The Pinkfingers
Vehicle: '94 Exceed
Stickers removed.
Took off the BF Goodrich and the Japanoid stickers. I have a new Japanoid sticker to put in a different place, and will hopefully get a deli.ca sticker from Falco. The BFG sticker on the white bar left behind a grey patch. Hopefully the delica sticker is of similar size, or else will need to repaint. It looks like someone already repainted while the BFG sticker was still on there.
Used hairdryer to remove the stickers and azulene oil to remove sticky residue.
Here's a close up of part of the grey patch.
Right on Pinkfingers! Good luck with the delica.ca sticker covering the grey spot. Even if it has a little bit of grey fringe around it, it'll look great! Expecting pictures... :-D :M
Cool, Pink....
You should still have my number in you PM file, if not PM me with your number and I can call you. You're going to need $3.00 for the sticker/$5.00 for a pair. Cheers!
The Pinkfingers
Vehicle: '94 Exceed
Lol, I was going to call you today, but ran out of time. But will call - keep two on hold for me. :-)
Schwa
Vehicle: 1992 Delica Exceed
Post by Schwa »
I had success getting the grey off my paint with a product called Krud Kutter from Home Despot, should you need to.
