This is by no means all of the modifications I have done but since I had an about the home kind of day
I thought I would take a few photos and show you all some of the things I have done with (to) my van in the last two years of owning it.
So buckle in and here goes...
The first main thing I did was build a rack.
The rack is in need of a little paint these days but it has seen a lot of abuse (tree branches, boat loaded on top, etc) overall it has done very well.
The second priority was some onboard entertainment. I decided I wasn't interested in the new batch of small dvd players
based on the screen size. So.... I went for a 13" lcd tv I got from superstore for $190 and the smallest dvd player I could find from Crappy Tire.
As you can see I did build a case around it and a swivel bracket for prime viewing. The case really helps to handle the kicks that it gets from my
three year old!
Next on the list was to add some real tires(31"x10.5"x15") and locking hubs (montero hubs work)
I did very little to accommodate the larger tires aside from removing mud flaps, adjusting torsion bars and a small amount of metal relocation with a hammer!
At about this time I started to get a little concerned with exposed radiator after finding a dead robin in there and a few nicks out of the fan.
I had picked up what I thought was an interesting piece of metal from the recyclers and I realized it would fit the need pretty well. so I ended up with this...
It has worked very well for me although we don't have quite the same snow concern here then other parts of BC.
I did warn you that this was going to be a long post didn't I?
Carrying on. I have also removed the back bench from my van for more space and I had the concept of a modular rear end
which I could change around to suit the needs of the activity, trip etc. The first thing that I did was build a "camper unit" that is
light weight and held in with only two bolts. This means that it is fairly easy to move in and out of the van. It has a propane
stove with a small 5lb bottle, a sink (grey water drains onto the mud flap) with old school pump facet, a twenty litre aluminum water tank,
and plenty of storage.
This is not a great picture but you get the idea.
I also wanted to have something a little more rugged in the back for packing my outboard motor, tools, and what not.
So I built this liner out of 1/8" aluminum checker plate.
It is actually three pieces (base and two wheel well covers) so that I can get it in and out easily.
I managed to work in a couple D-rings for tying down items.
I have also built a bumper with a class II hitch and some tie down points for my boat.
I wanted it to look as stock as possible at the time so I reworked the original brackets added a beefier bar and the hitch.
I am planning a new bumper but I haven't totally figured it out yet it will be a suprise!
I have just recently built a couple of new rear shackles to bring the van up about 1.75" higher in the rear. Combined with the torsion bars re-indexed
I have the van at what I think is a perfect height for me.
I still need to replace the rear shocks but I have already done the fronts. I would like to get some beefier torsion bars at some point but they seem
to be a little bit of a challenge to find.
If you look closely in the previous photos you should also the veggie oil tank that resides where the spare used to. This is what the tank looks like:
And where I fill it:
The most recent item I have completed is removal of the front license plate bracket. I have not liked this item since I got the van.
It is always bent and seems to be a target for corrosion. So one day I got out the grinder and got rid of it!
I was able get the four spot welds nicely ground and painted up the area. I cut the license plate up a bit and hose clamped it around the bar.
Legal? I am not sure but the original plate was pretty far gone so if at some point I have to replace
this one so whatevs. (don't worry I have fixed the oil leak)
I think it is a whole pile cleaner looking than before. Speaking of clean! You will have noticed from the pictures that my van is definitely
not clean. It tends to get a little neglected in the winter time based on not wanting to clean it every time I go out (the roads I travel
are really that dirty)! Here is some proof that it does get some care and attention in the cleanliness department.
I also need to deal with the underside of the van and have bought rocker guard for the under side and wheel wells which will happen fairly soon!
I am currently working on a awing that I am really excited about. I got the material off of ebay; marine quality 9.5 yards of nice
black and grey for only $30. I also have a sail boat mast which will be perfect to house it all.
Also in the works is a bench for the wheel well opposite to the camper unit which will have a 12v cooler built in. As well I have
the old table from my VW which needs to get worked in before this summer.
Well I know this has been pretty long (maybe a record: any way of checking this?) post but I have enjoyed this van immensely, will continue to
and wanted to share some of that.
Thank you for looking.
Andy
Call me BCDelica-less
