Since some hard driving and multiple water crossings on the weekend my clutch is intermittently harder to press than usual. Often now it is no longer smooth at the fritction point but tougher to press in that spot. Hard to explain, it basically is some rough feedback as you press sometimes, but other times it is normal and smooth.
Is this a sign of the clutch wearing out, cable needing lube, or worse?
I am told the clutch can be "tightened" to give it a bit more service life before replacement, should I do this or have a mechanic take a look?
Thanks in advance!
clutch hard to press! (5spd)
- BadgeStar
- Vehicle: '93 Delica L300 'The Black Van'
Re: clutch hard to press! (5spd)
I would guess that as you say you have done some 'water crossings' you've probably got water into the clutch cable which has washed out some of the grease (lube) and making it stiff to operate.
Barry.
Barry.
- Erebus
- Vehicle: 1992 Super Exceed
I don't have a manual, but I seem to remember reading that the clutch is hydraulic, not cable operated, and that it shares the fluid with the brakes. In which case maybe you got water in the fluid? If this is true, since it is a common reservoir with the brakes, might be worth replacing the fluid, since water in the brake fluid is really really bad.
Hopefully I'm wrong and you just snagged the clutch cable!
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".-
coaxial
interesting.. could using my brakes while all my wheels were underwater cause this
I'll take a look at the fluid in the reservoir anyways...
- Erebus
Shouldn't, since the brake lines (and the clutch for that matter), are sealed and only the reservoir on the dash has any opening.coaxial wrote:interesting.. could using my brakes while all my wheels were underwater cause this?
But hey, theory and fact are strangers too often.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".- jrman
A major long shot here, but have to post since this is similar to something I experienced with my 1985 Ford Diesel - the firewall developed a crack in it - so there was some flex in the firewall as I pushed in the clutch - giving it a "tougher" feeling, and making gear changes more difficult. I ended up having a plate welded in behind to beef up the firewall. Again - understand this is a long shot - and would suggest your problem is more likely related to recent driving activity, but thought I would throw it out there for consideration....anything is possible.
Sean in North Van
1991 Delica Exceed - Scoobus
- BadgeStar
I just checked the wife's Delica (which is a manual 'box) and you're quite correct! The clutch IS hydraulic so you can ignore what I said about the cable! I must have been getting mixed up with one of my old vehicles.Ruminante wrote:I don't have a manual, but I seem to remember reading that the clutch is hydraulic, not cable operated ....!
Barry.
