Parking Brake Warning Light - always lit
				Frisch
- Vehicle: Mitsubishi L400
So my Parking Brake light is always lit. I started dismantling and found the switch, which I believe grounds the circuit when the brake is on. It looked fine. I proceeded to disconnect this wire at two intervals along its path (it had two connectors) and nothing changed. That got me as far as the dash and my back started to bother me more than the dysfunctional warning light, so I called it a day.
Can anyone verify my thoughts on the switch being to ground? Any other ideas?
- loki
Re: Parking Brake Warning Light - always lit
that light also warns of low brake fluid, I would check that first.
				asorensen
The brake system and clutch cylinders share the same reservoir for the manual transmission model.
I have had that light show for two situations:
Low brake fluid as already noted (this was I think caused by a seized caliper which was weeping) and
Clutch slave cylinder failure (also leaking) which I just finished fixing last week. (Glen from CC Autos got me the part)
If you have a manual this second item might also be the cause of the warning light.
Andy
Andy
Mine has come on a few times from low brake fluid, and it should be noted that "low" isn't all that low and is still above the "min" line on the reservoir. So even if your brake fluid level "looks" ok, it's still worth adding a bit.
I obviously have some very slow leak in my brake fluid... but I don't know where... in just over a year of ownership I've had to top it up twice, maybe a couple of tablespoons lost....
I don't have my manual readily available to check, but I do remember that the brake light is an indicator for the whole brake system. It indicates if the parking brake is engaged, but it also indicates a problem with braking.
				Frisch
Thanks Loki, J.Paul, and Andy. It was! just my brake fluid. Next time, I might ask first and avoid dismantling the vehicle...maybe.
David
						David
				Krackie
- Location: Victoria, Tofino and Ucluelet, British Columbia, Canada
I must be blind, but i can't see the brake fluid resevoir . . . can someone illuminate me?  My light has been on for a bit and my brakes have bottomed out within a very short time.  Wondering if it is just the fluid?
						- loki
open the drivers door, and it is behind a plastic cover on the side of the dash.Krackie wrote:I must be blind, but i can't see the brake fluid resevoir . . . can someone illuminate me? My light has been on for a bit and my brakes have bottomed out within a very short time. Wondering if it is just the fluid?
				Krackie
thank you very much!
topped it up with fluid but the brake pedal still bottoms out :(
You have a leak somewhere in the brake system and now have air in the system from running out of fluid. Go see a mechanic, stop driving.
						- robinimpey
- Vehicle: 1991 Starwagon
Green1, have you checked your rear wheel cylinders? I replaced mine as they were leaking just enough to make dust stick to them, but over a period of time would use a little fluid. This is a classic place to lose fluid without having noticeable problems with your brakes. If they are leaking and leak too much the fluid can mess up your rear brake shoes.Green1 wrote:Mine has come on a few times from low brake fluid, and it should be noted that "low" isn't all that low and is still above the "min" line on the reservoir. So even if your brake fluid level "looks" ok, it's still worth adding a bit.
I replaced both wheel cylinders one evening after work. It was a quick easy project and each cylinder was around $30.00 from NAPA.
				definingdigital
- Vehicle: Delica
Just ran into the same issue. My Parking brake came on a while back, I thought it might be a short or something. Just found this post today, topped up the brake fluid and light went out. =)
				takeuchi
- Vehicle: 1992 Starwagon Super Exceed
I'm glad you posted this as I had the same problem.definingdigital wrote:Just ran into the same issue. My Parking brake came on a while back, I thought it might be a short or something. Just found this post today, topped up the brake fluid and light went out. =)
				Captain America
- Vehicle: 1990 Delica exceed l300
I can verify as well. When I first got my van the parking brake light was always on. Topped it off with brake fluid and the light went off.
