wipers question
- windsnob54
- Vehicle: 92 exceed
wipers question
Here's one... just noticed this today. My wipers keep working even with the ignition off. The thermometer is also always on. I'm assuming this is not supposed to be the case. Anyone know the circuit for the wipers? thermometer?
thanks,
Martin
thanks,
Martin
92 Passat Syncro wagon 1.9td
92 Delica Exceed
92 Delica Exceed
- mdrive
Re: wipers question
Wrong DRL connection. Someone did a 12volt feed through wiper connection.
- windsnob54
Re: wipers question
I don't think it's the drl, even when i disconnect that module entirly, the wipers still function with no key. do you know where the wiper relay is?
92 Delica Exceed
92 Delica Exceed
coaxial
Re: wipers question
you don't have a turbo timer do you? Mine has a timer and several electrical things stay on if the timer is turned on.
- windsnob54
- niekt
- Vehicle: L300 4x4 2,5 TD
Re: wipers question
Do you mean with just the ignition off or also with the key removed because my wipers also still function with the key in the acc. position but don't work with the key removed...My wipers keep working even with the ignition off
Niek
2001 L300 4x4 2,5 TD
Re: wipers question
Ditto, wipers work in ACC but not when key in OFF or key removed.niekt wrote:Do you mean with just the ignition off or also with the key removed because my wipers also still function with the key in the acc. position but don't work with the key removed...My wipers keep working even with the ignition off
- windsnob54
Re: wipers question
no they work even with the key not in the ignition. there is a constant feed occuring but where from??? wierd!
92 Delica Exceed
92 Delica Exceed
- Schwa
- Vehicle: 1992 Delica Exceed
Re: wipers question
do you have an aftermarket stereo installed? it could backfeed the acc circuit somehow.
- windsnob54
Re: wipers question
yeah that makes sense 'cause the stereo install is a hackjob to say the least! anyone know what wire i should be looking for?
thanks!
thanks!
92 Delica Exceed
92 Delica Exceed
Re: wipers question
Okay, here's what I can decipher from the schematics (solid colour w/ stripe):windsnob54 wrote:yeah that makes sense 'cause the stereo install is a hackjob to say the least! anyone know what wire i should be looking for?
thanks!
Green w/ White: input power
Blue w/ White: ground, and tracing it back , it looks like it's common with the wiper circuit
White w/ Red: right speaker positive
Red w/ Blue: left speaker positive
Gray: negative speaker feed, with the left speaker piggy-backed off the right (this could be why the left is the common 'dead' speaker, or why both will be dead together)
A proper connection is either soldered and heat-shrinked or crimped together with fasteners - not twisted and wrapped with black electrical tape (this works, but it has a way of loosening and shorting).
Hope this helps. If I've got the colours wrong, please correct knowing that the drawing is a pdf of a photocopy. Does anybody have a GOOD pdf of the electrical schematics?
- jwfchase
- Vehicle: '92 Super Exceed
Re: wipers question
Ha ha ha! I just finished doing a hack job stereo installation myself (temporary situation while I try to find proper stereo mounts) a few minutes ago. I accidentally touched the dash light wire to the power wire and it did backfeed and lit up the dash as if I had the headlights turned on. This makes me think that if the constant power wire and the switched wire are touching, the constant wire (the one that keeps the stereo clock from resetting every time you turn the ignition off) could be backfeeding the switched one, which might make all your accessories useable all the time!
