I've found a good catch can to install on a L300
.https://www.forefrontindustries.com.au/ ... -universal
Picture after installation.
							Forefront Catch Can
- Strada 92
- Vehicle: Mitsubishi Delica L400 1995
Forefront Catch Can
				- IMG_20170824_183530~2.jpg (445.31 KiB) Viewed 14528 times
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
				blackbrent
- Vehicle: L300 Exceed
Forefront Catch Can
Thinking of installing one on my '93 L300 4D56 turbo diesel as well - how do you like this can? Any pros/cons/issues?
				blackbrent
Forefront Catch Can
Also curious - did you cap the oil drain or run it back into the sump?
						- Strada 92
Re: Forefront Catch Can
Works very well. Cleaning one or two times a year. Keep intake and turbo clean. I've just cap the drain nipple. No return to the sump.
				remlarralmer
- Vehicle: TOYOTA HIGH-ACE
https://elmontecustomcabinets.com/ I’m thoroughly impressed with this! The quality and thoughtfulness you’ve put into this project are exceptional. It’s clear that you’ve put your heart and soul into this, and the results are truly impressive. You should be very proud of what you’ve accomplished. Well done!
