Depo headlight
liquidmonkey
Vehicle: 92 L300
Depo headlight
Post by liquidmonkey »
I've had my 92 L300 for a couple years now and am just getting around to switching the headlights. I got the headlights a year ago but never switched them at that time. When I went to do that this weekend I found that the plugs don't match. The wiring from the van is a 3 prong female (traingular) and the wiring from the headlight assembly is a 4 prong male (square).
I'm going to have to cut the plug off the old light and put on the new headlights. Anybody else had to do this or have you been able to plug van to light no problem?
Rising Sun Auto Import
Re: Depo headlight
liquidmonkey wrote: The wiring from the van is a 3 prong female (traingular) and the wiring from the headlight assembly is a 4 prong male (square).
You are right.
Steven :M
TardisDeli
Re: Depo headlight
Post by TardisDeli »
x2 Use the old headlight plugs.
Christine
sealica
Depo headlight
Post by sealica »
Rising Sun Auto Import wrote: Mon Nov 26, 2012 7:43 am
You are right.
Steven :M
I just want to triple check before going about chopping the connector off my new headlights that this is in fact the correct solution.
Wiring a 4-prong female connector onto the van’s harness is not done?
I got the idea from the parts supplier that I acquired the lights from that I shouldn’t splice any connectors to the new lights / that the van’s wiring should be modified to accept Depo headlights without any changes to the headlamp itself. Maybe something got mixed up over the phone and they just don’t want to accept liability for a poor splice job (very fair)?
Wiring from van:
Connector on new Depo headlight:
Connector spliced onto my old headlights (where the solution in this thread was apparently employed; by previous owner or mechanic):
sk66
Vehicle: '91 Delica L300
Depo headlight
Post by sk66 »
If you modify the van's harness, then you are dependent on the aftermarket parts and an "unknown" connector for any future changes/work.
Steven
1991 L300
Harrisburg, PA
