Hi everyone
I don't have the DRL on my van, I guess it got over looked by the inspector with the previous owner. I am going to install them. But this makes me wonder if I have the proper headlights now. They have the projector style with these numbers on the lens:
HCR
04
E13 20
0370
Anyone know? I could post a picture if that would help.
Thanks, Gerald
Are my headlights compliant?
Shimmertron
- Vehicle: 92 star exceed
- delicat
Re: Are my headlights compliant?
Your headlights are fine, they have the E13 code, (they should also have either an arrow or a L, R, to indicate direction of the beam projection) but with the "E" code you're good to go.
E13 is good to go, but always be careful, because some E codes are ok, others are not, has to be E code for a country that drives on the right side of the road (13 is germany, so it's ok)but with the "E" code you're good to go.
